Scanner for XK8
Old Apr 14, 2015 | 11:04 PM
stetson1's Avatar
Default Scanner for XK8
Thinking about getting a scanner and am wondering if there is one that shows engine/coolant temperature in real time, WITHOUT rewiring.
I've looked at the ScanGauge page and see one of the 'bullet points' of the unit is indeed: Coolant and Intake Temperature
Anyone have a scanner in their XK8 that shows the temperature?!
Many thanks,
frank
Looking at getting the ScanGauge2. It does display the coolant temperature, with some lag in time, but it's in seconds, I believe. And, it is black and slim in appearance.
Anybody have one and can verify the COOLANT TEMPERATURE feature and how it works, so far as showing the temp in real time?
thanks again!!
update:
Old Apr 15, 2015 | 01:01 AM
bakntyme's Avatar
I use the UltraGauge on a windshield mount. You have your choice of dozens of gauges to display, including coolant temp. It also shows (and clears) trouble codes.
UltraGauge EM Plus OBD II Scan Tool & Information Center
Old Apr 15, 2015 | 01:37 AM
woox4's Avatar
Scangauge works on my '05. Gives coolant & intake temp, fuel pressure and volts, among other things.
A cheap Bluetooth OBD reader and the "Torque" app on a smartphone also works well. I use the Bluetooth and app more than the Scangauge as there are no wires and it gives you gauges where the Scangauge is just four numeric readouts.
Old Apr 15, 2015 | 09:33 AM
MRomanik's Avatar
Veteran: Air Force
+1 on the Ultra Gauge. I use it.
Old Apr 15, 2015 | 10:25 AM
DaveInVA's Avatar
I third the Ultragauge. Now if I can only get it back from the guy I lent it to 3 months ago...
Dave
Old Apr 15, 2015 | 11:24 AM
brgjag's Avatar
I use the torque app for droid phones.
Old Apr 15, 2015 | 04:19 PM
Gary G's Avatar
I use kiwi wi-fi with the free OBIE app for all you apple fans.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
tlynch
Dec 31, 2020 01:58 PM
mikiep
Dec 20, 2019 07:37 PM
CXJ
Aug 29, 2017 08:41 AM
