Seeking part..
Hi - I'm in Canada and need a headlight ballast for my 2003 XKR. Jaguar Canada says they don't have one and want to sell me the entire headlight assembly. So, here I am - does anyone know where I can purchase one? Or is there an alternative option out there - replacement part?
All help appreciated.
Thanks.
Thanks.
I also go to Amazon. There is a leak somewhere in my headlight that causes the ballast to go out if I drive through deep water. Typically the flash flooding we see on the side of the road in a Florida summer storm. The ballast used to be well over $100 but I just checked and they are now $40 on Amazon! Here is the link:
I checked but the link informs me that this will not fit my 2003 XKR Jag unfortunately, even though it does appear to be a 12-pin ballast, which I need.
Thanks again.
Cheers.
I will check it out with my mechanic, especially since it works in your exact same car.
Thanks for the help.
Cheers.
Cheers.
I own a 2006 XK8 Victory Edition with HID and just replace one ballast without problem with a new one from Headlights Experts.
https://www.headlightexperts.com/hea...cement-ballast
Michel from Montreal
Hi - Just wanted to say thank you! I ordered the part and got it put in, everything works well. Thank you again for the help.
Cheers.
Cheers.
Thanks for your help.
Cheers!
Hey that is great news! Glad it worked. Ha, I do not like replacing my ballast but now when something happens at least it is not $150 or more like it used to be. Cheers!
Interesting this may explain an issue I have had since day one. My driver's side headlight is always very dim. I wonder if I have the 35 watt ballast in instead of a 50 watt ballast.
