Sensors
Po333 high input on bank 2 knock sensor
p1646 o2sensor open ciscuit bank 1
p1647 o2 sensor open circuit bank 2
these came up at the same time and will not clear can the failure of the knock sensor cause the other two or is there a common connection block that has failed
thank you
thank you
