Serpentine belt removal
Old Apr 30, 2020 | 04:55 PM
MattArnold's Avatar
Default Serpentine belt removal
Hi Guys,
I will be changing the power steering pump shortly. I have the procedure for that, but does anyone have a procedure for removal and refit of the drive belt?
many thanks in advance.
Car is 96 XK8
Old Apr 30, 2020 | 06:05 PM
avern1's Avatar
It is fairly straight forward. With a wrench/spanner on the tensioner pulley bolt head and push it toward the center of the engine to remove the tension. See attached routing diagram. Piece 4 is the tensioner pulley
Old May 1, 2020 | 09:18 AM
David Dougherty's Avatar
Default One suggestion
Originally Posted by MattArnold
Hi Guys,
Car is 96 XK8
The belt on my 2000 xk8 was pretty tight. One tip for removal and replacing would be to get a serpentine belt tool. The tool is nice and long and makes it easy to get the leverage required. Many auto parts stores will loan you the tool. To make putting the belt on easier the tensioner on my car has no lip to go over so I just put a little silicon on it and with the tool was easy to just slip it on. My reason for changing the belt was a alternator replacement.
Old May 1, 2020 | 09:20 AM
JimmyL's Avatar
I did this, and just an observation - it looks straightforward, but it's amazing how many ways you can thread a belt around those pulleys, but there is only one "right" way !
Old May 1, 2020 | 09:44 AM
Jon89's Avatar
2006 XK8....
I replaced what I assumed to be the factory serpentine belt in July 2018 when I had to remove the radiator fan assembly in order to remove the alternator so I could take it in for refurbishing. Much easier to replace the serpentine belt when the radiator fan assembly is out of the way and the hood is raised to the service position....
Old May 1, 2020 | 02:32 PM
brinny's Avatar
Does the pulley need changing too?
poisonpill
Aug 6, 2018 02:40 PM
hawaiianjag
Dec 7, 2015 07:54 AM
larueb
Apr 19, 2014 09:50 AM
andrewfulton
Apr 17, 2014 10:58 AM
Amphicar770
Jan 3, 2012 02:42 PM
