Shock Conversion
Old Apr 29, 2020 | 02:26 PM
Speedball's Avatar
Default Shock Conversion
Is a change from electronic front shocks in a 2000 XKR Convertible to Bilstein shocks a bad idea or otherwise contraindicated?
Not interested in paying the premium for OEM parts.
Thanks in advance.
Old Apr 29, 2020 | 02:37 PM
Higgins's Avatar
OEM shocks for all the X100 cars are Bilstein. Xkr:s all have Bilsteins with adaptive damping while Xk8:s had non-adaptive dampers as standard and adaptive ones as optional. But all are Bilsteins
Old Apr 29, 2020 | 03:09 PM
ccfulton's Avatar
There is no issue to swap the CATS shocks for regular, but you will need to change all 4 and unplug the module in the boot to eliminate the warning light. If you only change the fronts then the rears will be forever stuck in "firm" mode.
lidesign
Jul 20, 2012 06:03 PM
oldjaglover
Oct 28, 2011 01:27 AM
viscoussquirrel
Apr 24, 2010 10:47 PM
