Special Tool Rear Bearings
Old Mar 12, 2010 | 09:47 AM
southlandmechser's Avatar
Default Special Tool Rear Bearings
99XK8, While rotating my tires I checked the top to bottom play on the rear bearings; I found movement. I also discovered I need to do a complete brake job front/rear and replace both the front strut mounts. I was researching parts when I was told I would need a special tool to replace the rear bearings. If this is true where can I order/acquire this tool?
Also, what the general opinion on replacing the rotors and pads front/rear with ceramic pads and slotted/drilled rotors vs. OEM?
Old Mar 12, 2010 | 10:04 AM
Gus's Avatar
Gus
Before you change the bearings on the rear check and see if your universal joints are not creating the problem.
Old Mar 12, 2010 | 10:42 AM
daddyo007's Avatar
If you have vertical play (top to bottom) when you move the rear tire and not horizontal play (left to right) that is normal according to my jag dealer. I have a 99 xk8 coupe.
I had this same issue a couple of months ago.
Old Mar 13, 2010 | 07:32 AM
Normal...Wow, that's great to hear. I have enough to do on the car without worrying about the bearings.
philwarner
Sep 5, 2015 10:05 AM
Joey T
Sep 3, 2015 05:31 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
