Staggered vs non staggered question
Old Mar 8, 2015 | 12:53 PM
Jandreu's Avatar
Default Staggered vs non staggered question
I have 19" staggered rims, 8" on front and 9" on rear. If I change to non staggered is there anything to consider other than all 4 rims being the same size?
Wil 9" rims work/fit OK on the front?
Will 8" rims look OK on the rear?
Any idea what the min/max offset is that can be used on both the rear and front?
Old Mar 8, 2015 | 01:54 PM
ccfulton's Avatar
9" will work on the front, depending of offset.
For a brief period I had the 9" rears on the front of my car, and the 35mm offset is just about the max. The OEM 9" fronts are a 25mm offset.
The OEM 8" wheel was a little skinny for the back, IMO, although I suppose you could use a spacer on the rear to improve the look.
If you find a 9" with an offset between 25 and 35, it should be fine.
Old Mar 8, 2015 | 06:57 PM
Jandreu's Avatar
Looking at a set of 18/9 with 24 offset. Plan to use 255/40/18 tires on all 4
Old Mar 8, 2015 | 09:21 PM
ccfulton's Avatar
That should work well, it's pretty close to the stock 20" front wheel width and offset.
slojotaa
Oct 16, 2019 10:22 AM
2010 Kyanite XFR
Feb 16, 2016 11:40 AM
kamiar
Sep 17, 2015 06:30 PM
Mbourne
Sep 14, 2015 09:21 PM
DustysSon
Sep 13, 2015 04:17 AM
