starter not engaging
Old Jul 22, 2011 | 04:13 PM
test point's Avatar
Welcome to the forum!
Sounds like the old saying: 'rode hard and put up wet'.
You are probably correct that the starter just needs to be 'bumped'. Try that or replace the starter.
Old Jul 23, 2011 | 10:06 AM
BobF's Avatar
Sounds like the starter pinion gear is not engaging the engine ring gear.
Link to starter writeup
Starter motor - Wikipedia, the free encyclopedia
Old Mar 5, 2013 | 03:21 PM
kevpatts's Avatar
Hey, sorry, first post here. I have exactly the same problem. I'm not sure what you mean by "bumped". As an automatic it can't be jump started, do you just mean hit with a rubber hammer or something? If so, must be done from below, right?
Kevin
Old Mar 5, 2013 | 07:09 PM
test point's Avatar
Long, long ago in a far away place I kept a 3' piece of a wooden broom stick in my '56 Chevy to 'bump' the starter when the solenoid failed to throw out the starter gear. Worked then, probably will work now.
Of course, now we just replace the starter.
. . . and welcome to the forum!
Old Mar 6, 2013 | 08:03 AM
oldmots's Avatar
Before replacing the starter, load test the battery, you may not have the amps to activate the solenoid.
Old Mar 15, 2013 | 12:27 AM
gray cat's Avatar
Default testing a starter
is it possible to test the starter on a 86 xj6 while on the car ?
ricwel
Jun 23, 2023 05:14 PM
goingjag
Sep 30, 2015 09:27 PM
millertic
Sep 30, 2015 08:11 PM
backstop44
Sep 30, 2015 12:19 PM
