Steering wheel position memory faulty
Old Oct 17, 2017 | 09:20 PM
Burnham's Avatar
Default Steering wheel position memory faulty
The mirrors and seat position seem fine, but the steering wheel fails to return to the set memory position. It drops to near the bottom of the range, lower than the set location. In and out stays put, but my set position there is all the way in, so it doesn't need to move.
If I repeatedly push the button to recall the memorized position, eventually the wheel gets there, a bit at a time.
Any thoughts on cause or repair?
Old Oct 17, 2017 | 10:57 PM
baxtor's Avatar
Very similar to my old issue. There is a wire snip solution fixed it for me. Search "a different tilt motor solution" will turn it up but from memory it is blue/white wire at the tilt motor under steering column, just needs to be cut, no downside.
Old Oct 18, 2017 | 02:41 PM
Burnham's Avatar
I did do that mod, Bax. Worked fine for my earlier issue, which was somewhat different than this. In that case, the wheel wouldn't move far enough to reach the memorized position.
Now, it moves past the memorized position.
Old Oct 18, 2017 | 02:56 PM
RDMinor's Avatar
Default There are severl threads dealing with this problem
Here's one such thread.
https://www.jaguarforums.com/forum/x...fix-faq-53768/
Old Oct 20, 2017 | 05:22 PM
Burnham's Avatar
I did that repair as well, before the wire snip...twice...did not have success.
Yesterday after a few start/stop cycles on a trip to town on a variety of errands, the wheel started behaving correctly. I dunno.
Old Oct 23, 2017 | 10:21 PM
Burnham's Avatar
Well.
Basically, ever since I made my original post, the damn steering wheel position memory has worked as intended.
I have to assume this means the lovely Jag XKR is a sentient being, monitors my internet activity here, and does not want me to snip any more wires, or pull and mess with any more $625 electric motor/gear drives.
Thanks, all.
