Transmission oil temperature sensor
Old Oct 23, 2017 | 01:12 PM
Gcon's Avatar
Default Transmission oil temperature sensor
What is the part number?
Where can i find parts?
How can i change it?
Old Oct 23, 2017 | 02:44 PM
avern1's Avatar
Go to this link and fill out a parts request. They are very prompt at returning info and are very knowledgeable. New and Used OEM and Aftermarket Jaguar Parts Online Catalog
Old Oct 23, 2017 | 02:46 PM
larueb's Avatar
If you are getting the warning pop up on the screen, it is not uncommon. When I had mine rebuilt they used the old wiring harness and it popped the warning for a few weeks. Scared me! Seems the wiring and connections get old and brittle and send a false signal. The real downside is if you decide to repair or replace the wiring, you have to drain the transmission and fill it with the very overpriced transmission fluid.
Not sure what your issue is but this was mine and it was a false signal.
Old Oct 24, 2017 | 07:46 AM
Barry_Tucker's Avatar
Use Mercon SP...same stuff.....much cheaper
Old Oct 24, 2017 | 08:50 AM
motorcarman's Avatar
There THREE diferent gearboxes associated with the XK series from 1997 to 2006.
WHAT CAR DO YOU HAVE????????????????????????
bob
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
JigJag
Oct 17, 2016 01:49 AM
Daim
Oct 9, 2016 03:08 AM
sjuraud
Aug 28, 2010 02:11 PM
racerx82
Dec 10, 2008 05:02 PM
