Transmission oil temperature sensor
Go to this link and fill out a parts request. They are very prompt at returning info and are very knowledgeable. New and Used OEM and Aftermarket Jaguar Parts Online Catalog
If you are getting the warning pop up on the screen, it is not uncommon. When I had mine rebuilt they used the old wiring harness and it popped the warning for a few weeks. Scared me! Seems the wiring and connections get old and brittle and send a false signal. The real downside is if you decide to repair or replace the wiring, you have to drain the transmission and fill it with the very overpriced transmission fluid.
Not sure what your issue is but this was mine and it was a false signal.
There THREE diferent gearboxes associated with the XK series from 1997 to 2006.
WHAT CAR DO YOU HAVE????????????????????????
bob
bob
