Steering wheel won't drop down
Old Jun 5, 2011 | 02:45 AM
Frog's Avatar
Default Steering wheel won't drop down
When I switch off and remove the key, the wheel moves all the way in and up as it should. However, when I come to start up again, it moves fully out to my preset position, but will only move down about 1/2". When I try to move it down 'manually' by pressing the button on the steering column, it moves down in small jerks and I have to push the button 3 times for the motor to kick in normally and move the wheel to its proper position.
I have tried resetting the seat/wheel memory buttons, but it doesn't seem to make any difference.
Any ideas?
Old Jun 5, 2011 | 03:58 AM
test point's Avatar
There is a potentiometer associated with the movement motor that is a common problem. Some have removed the motor/pot assembly and cleaned with electrical contact spray cleaner. The up/down motor is not hard to remove.
I set the memory buttons on each side of the 'dead' spot and used the memory to cycle the motor across the spot. That fixed it for awhile but the problem came back.
A dealer will replace the entire motor/pot assembly.
Old Jun 5, 2011 | 06:52 AM
Frog's Avatar
Thanks for the info. Do you know if there's a how-to on getting at the up/down motor?
Old Jun 5, 2011 | 07:01 AM
Glenn Barickman's Avatar
This may help...and the price is right.
https://www.jaguarforums.com/forum/x...umn-fix-53768/
Old Jun 5, 2011 | 08:51 AM
Frog's Avatar
Fantastic!! This forum is SOOOO useful Many thanks.
Old Jun 5, 2011 | 06:58 PM
brgjag's Avatar
I know on my 97 the wheel would go in and out fine and up but to come back down it would move a tiny bit then stop. Hitting the button did no good so I gently hit/pulled down the wheel down while hitting the button then it would start going down fine. I did this process several times and it didn't do it again while I owned it.
It had not been moven up or down in ages so many she was just a bit STIFF???
Old Jun 7, 2011 | 05:17 PM
Jagalways's Avatar
On my 99 XK8 coupe there are two memory buttons on the door, and the button on the steering wheel has two positions, one for each memory button. So, you need to know which position operates which memory button. I just set them both the same.
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
JarodL
Mar 7, 2024 01:39 AM
PMKimpton
Aug 3, 2019 08:22 PM
Broken_Spanners
Sep 6, 2015 11:34 AM
