stolen car ??
Old May 4, 2013 | 07:46 PM
  #41
Wb5Tom's Avatar
Well went out two hours later and tried to start car to go for a ride (79 degrees no wind, nice riding weather) after I had closed every up and locked it up, car will not start so uncover ECM and TCM unplug ECM unhook battery and resistance is still 120 ohms each way, hook car back up (approx. 15 min and car starts) so I shut it off and lock it up to try again later. unhooked battery first before unplugging ECM
Old May 4, 2013 | 07:56 PM
  #42
Gus's Avatar
Gus
Well that was short lived! Back to the drawing board.
Old May 9, 2013 | 12:14 PM
  #43
Gus's Avatar
Gus
Any luck?
Old May 10, 2013 | 07:04 AM
  #44
Wb5Tom's Avatar
Problems remain, have had several "no start" conditions and have not been able to measure anything but 120 and 123 ohms in both directions from the ECM outward. Have been monitoring the fault indications on Autoenginuity ScanTool and it was showing interment can message faults at the instrument cluster so removed same and took it apart looking for problems that might be seen and cleaned the cable contacts in and out of the board and reinstalled unit back in car , so will see what happens next.
Old May 10, 2013 | 07:33 AM
  #45
WhiteXKR's Avatar
I am not a big fan of throwing parts at a problem, but there are usually a few used XK8 instrument clusters under $100 on ebay. If you do get one, a unit from a 2000-2002 non-supercharged XK8 should be plug and play. Make sure it has the yellow connector on the right, and not two black connectors.
Old May 10, 2013 | 08:56 AM
  #46
Gus's Avatar
Gus
Or you could have yours rebuilt.
Link Welcome To Auto ECU Inc.
Old May 10, 2013 | 03:35 PM
  #47
Wb5Tom's Avatar
since cleaning and re seating all connectors on the instrument panel I have been able to restart 10 or 12 times and drive the car around some during this time. Who knows maybe.
Old May 10, 2013 | 04:22 PM
  #48
Gus's Avatar
Gus
Sounds good!
Old May 11, 2013 | 04:22 PM
  #49
Wb5Tom's Avatar
Well put 75 miles on the baby today and stopped and started it 10 times with no trouble, but only time will tell ( watched can activity on Tm, Abs, and ICm and saw no errors today)
Wish to think all for the help, it sure made a difference as the instrument cluster was the last place I would have looked (it had the modified backing in the unit also)
Old May 11, 2013 | 08:21 PM
  #50
Gus's Avatar
Gus
The best thing you can do for this car is to clean the plugs as you go. One thing for sure XK8's do not like to sit idle! I wish you luck!
Old May 12, 2013 | 06:59 PM
  #51
Wb5Tom's Avatar
Sunday afternoon ride and it shut down with same display on instrument cluster, but when I looked at the dtc it only showed U2500 and p1797 and car restarted in about 3 minutes (shutdown was while driving this time) progress?
Old May 13, 2013 | 10:52 AM
  #52
xjrguy's Avatar
Refresh us again.......
What exactly, was the message(s) displayed??
Old Aug 14, 2013 | 09:42 PM
  #53
Wb5Tom's Avatar
Well after a summer off in the motor home I came home and have used the car daily for past 3 weeks and not a trouble one, prior to extended trip ,tried going around and tightening all ground connections I could find and the ecm has not reported a theft in about over 4 weeks of driving. Fingers are crossed for a while yet.
Old Aug 14, 2013 | 09:44 PM
  #54
Wb5Tom's Avatar
Thanks for all the help provided.
Old Aug 14, 2013 | 09:55 PM
  #55
philhef's Avatar
Mine did the same thing, but only in rainy weather. I replaced the battery, it was the factory one, and no problem since.
Old Jun 3, 2014 | 03:08 PM
  #56
Wb5Tom's Avatar
finally replaced the instrument cluster package and it cleared the dropped can message reports and allowed the car to be driven normally for 2 months daily (about 10 miles round trip ) Thanks to all for the help
Old Jun 3, 2014 | 07:24 PM
  #57
Jandreu's Avatar
Thanks for the update and to all that helped with the troubleshooting. What a great forum, I would have never bought my car if I hadn't found this place first.
Old Mar 12, 2016 | 01:13 AM
  #58
Sir Alex of Yotto's Avatar
This is an old thread, but I want to second the comment above: I was a reader of this forum while shopping for a used XK8; without the keen knowledge of the members within, I likely would not have pulled the trigger. The extensive knowledge shared here gives one the confidence to take the Jaguar leap and drive the car of our dreams.
Many thanks to the helpful members of Jaguar Forums!
Nati
May 16, 2020 08:30 AM
rvdz
Dec 7, 2019 06:42 AM
Jandreu
Aug 29, 2015 07:31 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
