Straight-through exhaust
Old Nov 6, 2022 | 10:36 AM
4 wheelz good, two legs bad's Avatar
Default Straight-through exhaust
I've got an '02 XKR and I'm wondering about doing up the exhaust. Elsewhere people write that such an exhaust will increase fuel consumption.
Will the reduced back-pressure from the exhaust reduce compression and performance?
I'm aware I may be giving away quite how amateur a mechanic I am!
Thanks in advance
Luke
Old Nov 6, 2022 | 11:46 AM
Stuart S's Avatar
You're in the wrong Forum. This is the X150 Forum, for 2006-2014 aluminum XK/XKR models. Your 2002 is the previous generation 1996 - 2006 X100 XK/XKR Forum.
And yes, reducing back pressure will reduce low-end torque.
Old Nov 6, 2022 | 11:47 AM
Stuart S's Avatar
Read this: New Members - Must Read!
Old Nov 7, 2022 | 12:54 PM
Cheers for pointing that out and answering the question Stuart. I can't see any way the X150 would differ to the X100 in that respect. I must have clicked the wrong button, I knew I wanted the X100 forum.
The question that leaves me with is why do so many people do it to so many cars?
I'm a biker by vocation, I also have a trike with a motorbike engine.
Old Nov 7, 2022 | 01:48 PM
Cee Jay's Avatar
Reducing back pressure will reduce torque, IF YOU DON'T TUNE FOR IT.
It's all about the tune.
Zero back pressure is your absolute god, as long as the tune is set for it properly and your intake can deliver what it must also.
With zero back pressure, the combustion fills completely with fresh unburnt air and fuel.
It's the tune.
It's ALWAYS the tune.
Old Nov 7, 2022 | 01:55 PM
mosesbotbol's Avatar
The car will drive like a dog without a properly designed exhaust. I tried the free flow exhaust and it was awful.
Old Nov 7, 2022 | 04:25 PM
jahummer's Avatar
As the old statement goes, a supercharged engine's an air pump, balance what goes in to what goes out, balance timing with air fuel ratios and you'll have more power... either re-map the PCM or use a stand alone.
Tom Connolly
UK & Eire
Apr 29, 2022 04:57 PM
Beginner
E type ( XK-E )
Jan 26, 2022 10:43 AM
Jaguar1611
Dec 10, 2021 02:39 PM
mushroom09
Sep 3, 2019 05:19 PM
makecopies
Apr 13, 2018 10:17 AM
