Suggestions to repair passenger window seal?
Old Jul 30, 2016 | 09:51 AM
Anthony8858's Avatar
Default Suggestions to repair passenger window seal?
XK8 Convertible.
A little cracking along the top of the passenger side window seal that runs along the convertible roof top.
It's still soft, and none of it's missing. A little adhesive should do the trick.
1) I was wondering if there was a way to stop the roof mid way to inspect all the seals? And if so,(knowing the delicate electronics, etc..) would it cause any problems?
2) Is there a way to SIMPLY change the trim without becoming a huge project?
** I'm a huge fan of "if it ain't broke, don't fix it"**
Old Jul 30, 2016 | 10:00 AM
WhiteXKR's Avatar
You certainly can stop the roof midway. When you do though, there is a good chance you may have to manually reset the roof afterwards if you leave it in that position for a while.
Superglue is pretty effective on weatherstriping tears.
Old Jul 30, 2016 | 10:04 AM
And for THAT ^^^ reason, I won't do it
I'll go with the superglue.
Old Jul 30, 2016 | 10:07 AM
Found this thread.
No need to further discuss.
https://www.jaguarforums.com/forum/x...acement-50653/
pilot435
Sep 2, 2024 08:09 AM
xjrjag
Apr 14, 2016 11:57 AM
Exterior
Nov 14, 2006 12:23 AM
Nov 5, 2006 12:00 PM
May 25, 2006 07:31 PM
