suspension fault
Old Apr 27, 2010 | 06:28 PM
Mustang II's Avatar
Default suspension fault
Hi
Im a newbie
haven't worked on a car for 20 odd years
so just starting to learn about engine management etc
Over the winter my jag started showing suspension fault and the engine light came on, so I plugged in a code reader my son got me and got the codes P0333, P0430, which is showing bank 2 high and bank 2 knock sensor, I have noticed a slight missfire at idle, I can't find anything on the suspension fault
also what side is bank 1, and 2 I am assuming bank 2 is right bank when facing the car
should have mentioned its a 2000 xkr 62K on the clock Cats? suspension rhd
can anyone throw some light on this its driving me nuts
thanks
Jim
Old Apr 27, 2010 | 07:07 PM
test point's Avatar
Bank 1 is the RIGHT side, sitting in the driver's seat, a more conventional way of describing left and right. Bank 2 obviously the other.
P0333 is a B bank knock sensor out of range. More likely an electrical connection than the unit. Engine compartment been wet lately?
P0430 is catalytic converter B bank (left from the driver's seat). List of problems starts with electrical connections and end with sensor itself.
Fix the P0333 first and the P0430 may go away.
Old Apr 28, 2010 | 04:28 PM
Mustang II's Avatar
Many thanks
lots of water and floods / typical scottish weather plus a local quarry that constantly floods the main roads,
I will have a good look at the week end
MrWhite
19
Jun 14, 2022 07:49 PM
magmedia
Aug 15, 2019 08:54 PM
leep123
Sep 30, 2015 03:41 PM
ChrisJay
Sep 27, 2015 09:08 AM
driver safz
Sep 26, 2015 06:01 AM
