Suspension gurus--- Castor question
Old Apr 15, 2015 | 03:32 AM
dannio636's Avatar
Default Suspension gurus--- Castor question
Hey
I have a 99 XKR with lowered springs, and poly bushes all round. It is on 19 inch alloys and P Zeros- new..
Whilst fitting the tyres I had the suspension set up.
Turns out that all is ok except the castor.
Car drives nicely but is a little to light on the from end for my liking and I think its the castor... Turns in VERY quickly...
Camber has been adjusted so that it is just in spec both sides, toe is spot on, that was very bad before... but my castor is as follows:
Front left 5 degs 58 min
Front Right 6 degs 02 min
In order to adjust this back to normal, do I move shims from the front of the arm to the back?
I think in upgrading to the poly bushes the settings will have changed.. Actually, I know they did as I did the work myself and I can't remember how many shims went front of the arm to the back..
I am hoping that this will ease the very lively front end..
Anyone tried this themselves? Hopefully they have.
Thanks...
Old Apr 15, 2015 | 09:04 AM
RJ237's Avatar
Increasing positive caster results in heavier steering. So if you move a shim from the rear to the front that should help.
Old Apr 15, 2015 | 09:36 AM
mhminnich's Avatar
RJ is correct. You want to move shims from the back to the front to increase the negative castor. It will make the car a lot less nervous.
Old Apr 15, 2015 | 12:03 PM
dannio636's Avatar
Hey
Thank you for that.
Any comments on the current caster settings? They don't seem to be too far off which is the worry.
Old Apr 15, 2015 | 02:53 PM
RJ237's Avatar
That's one thing I haven't paid attention to. If you have the alignment checked after moving a spacer, please come back with the numbers and the difference in feel.
Forcedair1
Feb 19, 2020 01:51 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
02jagstype
Sep 4, 2015 08:20 PM
Harry Dredge
Sep 3, 2015 03:04 AM
