Tail and Side Marker Lights not working.
Old May 4, 2022 | 11:36 AM
donald6948's Avatar
Default Tail and Side Marker Lights not working.
I have a 1998 XK8 the taillights and side marker lights stopped working. I checked the fuses and they are good. Has anyone experienced this problem? Any help will be appreciated.
Old May 4, 2022 | 04:28 PM
michaelh's Avatar
Are the front sidelamps & markers working OK?
Old May 5, 2022 | 12:50 AM
Pistnbroke's Avatar
you need an earth and a live ....time to break the meter out.
Old May 5, 2022 | 10:49 AM
donald6948's Avatar
No, the front sidelamps do not work either.
Old May 5, 2022 | 11:15 AM
michaelh's Avatar
OK,
I suspect that there may be an issue with the lighting stalk. The wires occasionally break at the switch due to constant flexing.
Member Johnken has posted a pic of the switch:
https://www.jaguarforums.com/forum/x...2/#post1619272
The Electrical Guide gives Red with Yellow tracer as the wire colours for the sidelamps. As PB notes, a multimeter will help with diagnosis if it's not something immediately obvious. That wire should be grounded whenever the switch is at the 'side' or 'dip' position.
Old May 6, 2022 | 08:38 AM
donald6948's Avatar
Thank you, i will try to investigate.
gatorVDP
Sep 6, 2019 12:01 AM
savhomer
22
Jun 6, 2013 06:11 PM
coastaljag98
Oct 15, 2012 10:19 PM
dspence1990
Oct 11, 2009 11:06 PM
