TB Plugs?
Old Apr 24, 2009 | 10:03 PM
Spurlee's Avatar
Default TB Plugs?
I've been researching a bit here on the fourm...
What/where are TB Plugs - somewhere in or part of the throttle body and...
What/where is the part load breather hole...again, in or around the TB, I assume.
I need to clean/replace this stuff and the MAFS before I go off the deep end
Interestingly, last week I hit a deer and did some minor damage to the drivers side bumper cover and center hood...I haven't opened it figuring I'd let the body shop mess with it.
The TB is pretty close up there...what's the likelthood that after a week a crack/leak gets bad enough to trip the limp home mode I had tonight?
Thanks!
Old Apr 25, 2009 | 06:35 AM
Gus's Avatar
Gus
Go to my web page and you should find all you need.
Good Luck!
Old Apr 25, 2009 | 07:50 AM
Spurlee's Avatar
Default Thanks
Most helpful! Thanks for pictures.
Hopefully this isn't the beginning of a loooong saga.
I'll disconnect the battery to clear everything, Sea Foam the intake, inspect the throttle body plugs and clean the MAFS.
I'll let you know what heppens.
Old Apr 25, 2009 | 01:11 PM
Spurlee's Avatar
Default Success!
A cleaning seems to have resloved the problem, at least in the short term.
There eas a good deal of dirt- sandy stuff - in the round TB plug. The installation positions the female "cup" downwards from the male slider - effectively making a trap for water and dirt. Think ahead Jaguar!
The larger TB plug pulled off too easy -that was probably the problem.
I sent my test driver (girlfriend) off to town, so we'll see....
Thanks for the help!
boiler
US Southwest
Dec 20, 2025 12:38 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
mat32essex
Oct 3, 2015 04:12 PM
hoodun
Oct 2, 2015 02:06 AM
