Which tensioner, mayonnaise and breather mesh.
Old Nov 29, 2014 | 07:21 AM
looops's Avatar
Default Which tensioner, mayonnaise and breather mesh.
Hi all.
Thought I'd check which upper tensioners I have and I can immediately see they are better than the originals because there's no separate mounting plate. Can't see in cracks on the just outer edge of the tensioner piston which is good.
The tensioner body is 40mm wide if that helps, the bolts are 35mm. Anyone know which generation of tensioner these are?
In the cover was a smear of mayonnaise, normally I associate this with water mixing with oil but there's not much here. Maybe it was just oil mixed with a little condensation?
Lastly when I lifted the cover a plastic plate and two wiremesh filters were just sitting around the cams. I've replaced them where I think they go but why would they just be lying around the cams? Could be they just fell away when I lifted the cover off.
Cheers.
Paul.
Old Nov 29, 2014 | 07:41 AM
batroute's Avatar
Those are third generation(metal) tensioners. Have a look at the primary guides whilst you have the valve covers off. For the stated mileage that engine is very clean inside - obviously had regular oil changes.
Old Nov 29, 2014 | 11:25 AM
looops's Avatar
It's all back together now but no bother to open it up again; can't think how I'd see the primaries though.
mikiep
Dec 20, 2019 07:37 PM
NathanDD6
Oct 6, 2015 11:20 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Johncy2000
Oct 2, 2015 01:05 AM
millertic
Sep 30, 2015 08:11 PM
