Is there a correct engine temp range?
Dont try to calibrate your real gauge to a IR thermometer, if you want to do it properly use a contact thermometer. IR thermometers are an indication only and should not be relied on as you will get a different temperature reading on different materials, surface finish makes a big difference as does the presence of scale /paint/corrosion. Its amazing how a bit of technology in a gadget makes people thing that it must be somewhat better than what we had in the past, you need to understand the devices limitations and use it accordingly
XJ6Paul
Jun 4, 2019 01:23 PM
