Is this thermostat broken?
Old Apr 1, 2023 | 04:06 PM
Todd Wiens's Avatar
Default Is this thermostat broken?
I ordered a new thermostat from the dealership. When I opened up the new thermostat, it’s in pieces. And the one that is currently in the thermostat housing is held in place under 2 plastic tabs under spring pressure. Did they send me a broken thermostat or do I have to assemble it? And, how do you release the spring tension to remove the old thermostat?
The currently installed thermostat
This is how the new thermostat arrived.
Old Apr 1, 2023 | 04:59 PM
michaelh's Avatar
The later stats do look like something conjured up by Rube Goldberg.
JTIS is no help on this one. It looks like you just have to press down on the formed metal bar and twist it so the ears disengage from the plastic lugs on the thermostat cover. I can't see where the smaller spring goes (probably on the spigot behind the plastic disc) but you'll find out when it comes apart.
Haynes: Retain small spring...
Translation: "Jeez what was that, it nearly took my eye out!"
Old Apr 1, 2023 | 07:17 PM
RJ237's Avatar
t should not have come in pieces. Maybe it's a returned part.
Old Apr 4, 2023 | 08:57 AM
kstevusa's Avatar
Default Stat Tool
Looks simple but near impossible to do. We made a tool to hold the end and allow us to press the spring down and lock. Info and pics in my thread ..the Stst. Search under username should reveal needed info. Goos Luck
Old Apr 5, 2023 | 01:58 AM
Pistnbroke's Avatar
Testing is put it in a pan of water and raise the temperature ..if you have a thermometer so much the better
trkyam
Jan 31, 2023 02:37 PM
Popstacle
Jan 30, 2023 12:24 AM
garethashenden
Jun 19, 2021 05:21 PM
Stamford
Aug 23, 2020 01:40 PM
ez64
Jul 25, 2011 10:38 AM
