Thermostat fitment - aluminium tower
Old Aug 25, 2024 | 11:48 AM
bladerunner919's Avatar
Default Thermostat fitment - aluminium tower
I have a 1998 car (AJ26) and some years ago fitted the aluminium thermostat tower. Whilst investigating a slight leak from the thermostat housing, I realise that the thermostat sealing ring is not under compression when fitted, as the recess that the thermostat fits into is deeper than the width of the sealing ring. I bought another thermostat to see if that was better, but same deal. I assume that sealing ring is supposed to be under compression?
Old Aug 25, 2024 | 01:06 PM
motorcarman's Avatar
Jaguar did offer the seal itself if that is all you need. (NCA2246BA)
You might need a different (new?) housing if the recess is not machined correctly.
I would try a thin spacer or additional 'O'ring behind the thermostat/seal assy to see if moving it forward slightly will help if that is the problem.
RTV can be used sparingly as a last resort.
Old Sep 9, 2024 | 07:27 AM
A follow up on this. I bought a Jaguar thermostat seal and, as you can see below, it's somewhat thicker than the one that came with the thermostat from a motor factor. The moral of the story is that the correct thermostat, in terms of size and opening temp, may not come with the correct gasket!
04Xjrsteve
Jun 10, 2024 12:18 PM
Popstacle
Jan 30, 2023 12:24 AM
garethashenden
Jun 19, 2021 05:21 PM
Stamford
Aug 23, 2020 01:40 PM
black vanden plas
Oct 22, 2010 08:59 AM
