Thermostat housing leak
Old Sep 3, 2014 | 09:17 AM
mikeeadyjr's Avatar
Default Thermostat housing leak
Everytime i fix a leak I'm the cooling system it leak from some where else....
Octo hose, throttle body hose, thermostat housing and 2 years later the thermostat again it's leaking from the side JB Weld or something. At first I thought it was just because of Old parts. my jag has the 4.2 engine 06. Any suggestions.
Old Sep 3, 2014 | 10:38 AM
larueb's Avatar
Not sure on your year model but check and see if the aftermarket metal thermostat housing is available and replace the plastic one. This is a common "must do" on the 4.0 motors.
Old Sep 3, 2014 | 10:57 AM
brgjag's Avatar
Before I bought another plastic housing I looked for the metal replacement, I never found it for 03 and up. So i put on another new factory Tstat housing.
Old Sep 3, 2014 | 12:31 PM
Gus's Avatar
Gus
JB Weld is a band-ad and not made for a permanent repair. The engine and coolant system gets hot and the pressure associated with it will breakdown any weak spots. Replace the housing.
Doug
Feb 27, 2019 01:31 AM
GordoCatCar
Jan 2, 2017 01:10 PM
Booskisjag
May 5, 2016 09:38 AM
abonano
25
Sep 25, 2015 10:43 AM
Tipptone
Sep 16, 2015 07:39 AM
