Thought It was Fixed.
Old Apr 9, 2011 | 12:39 PM
zmann96's Avatar
Default Thought It was Fixed.
Hi Guys,
Well, I moved the coil from #2 to #4 cyl. The code ( misfire) followed the problem from 2 to 4. I bought a new coil ( not Used) and put in #4 cyl. It ran great for two days, didn't code ( restricted performance). Third day the restricted performance was back and on #2 where it started from at first. I thought that maybe because it wasn't reving over 3000rpm that the oil may have gotten into plug hole after a few days of driving over 3000rpms. I just checked the #2 plug hole and it's dry. Could there be something that damaging the coil? It has been in #2 and only cleared when I switched the coils and then 4 was coding. Any suggestions ? I think the code was P0304 #2 misfire. I erased the code before I pulled the plug and it's still all opened up. Thanks in advance for any help.
Old Apr 9, 2011 | 04:30 PM
H20boy's Avatar
XKRs will not exceed 3000 rpm in P or N to limit damage...its designed for your engines protection from yourself.
Not sure about the codes or your misfire. What did plug No. 2 look like?
Just checked the JTIS, P0304 is A4 cylinder, Bank A is essentially, Bank 1. So, you're looking for cylinder 4, passenger side.
Looks like you were chasing the wrong cylinder. My bet is you have oil in cylinder 4.
Old Apr 10, 2011 | 05:42 AM
zmann96's Avatar
Default thanks
I couldn't remember the code because I cleared it before I switched the coil. I realize it will not rev past 3000 in P or N, it's when I've tested it after I checked the Cyl. I pulled the plugs and they look fine and no oil in the plug wells. Yesterday I switched #2 with #1 ( #2 was coding) I cleared trhe code both wells were clean no oil and the car ran fine for a half hour ride, I'll take it out fore a longer cruise today and see if I get a code in #1. I'm wondering if the coils are weak and if I should just replace but the car only has 53K miles on it. It's a 99.
Old Apr 10, 2011 | 07:38 PM
hlgeorge's Avatar
Check the connectors for the coils for corrosion.
Old Apr 10, 2011 | 08:05 PM
Gus's Avatar
Gus
The car has a limiter that will prevent it from revving past 3000rpm when not in gear. As for the coil pack connections, I recently replaced the plugs in both my 2000 s-type & 1999 xk8. When I did the job I sprayed all the contacts with contact cleaner and then checked for a tight contact and applied Dielectric grease sparingly. I use this process on all plugs that I pull apart.
In order to identify the real problem you should try to capture the codes and post them.
smartobject
Jul 6, 2016 05:28 PM
abonano
25
Sep 25, 2015 10:43 AM
strippersteel
Sep 15, 2015 09:35 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
tvholden
Sep 12, 2015 11:13 AM
