Throttle Cable Adjustment
Old Apr 3, 2013 | 07:11 AM
giandanielxk8's Avatar
Default Throttle Cable Adjustment
I can't, for the life of me, find how to adjust the position of the throttle cable on my '00 XK8. I found how to do it on the '03 (Sam's Vid) and I read the FAQ about it but it doesn't detail the procedure for my mdy. The links to the thread at roadfly seem to be borked as I get an error message from them.
Old Apr 3, 2013 | 07:15 AM
steveinfrance's Avatar
Loads of search results
eg
https://www.jaguarforums.com/forum/x...estored-38663/
but check first with OBD live data (if you can) that you need to do anything.
Also look in HOW-TOs under battery disconnect for training the throttle and kickdown.
Old Apr 3, 2013 | 09:11 AM
That's the same thread I checked earlier. I didn't see the procedure for the '00 car. I'm not sure if Gabriel's quote applies to me. I pull the plastic but the only thing in there is the brake fluid. The throttle on my car is in plain sight but I don't see a way to adjust it. I already checked the OBD live data, I've got a 67% right now.
Old Apr 3, 2013 | 09:50 AM
Have you tried the retrain procedure ?
The adjustment procedure described has been used with success by other 2000 MY owners so shouldn't do any harm if a retrain does nothing.
Old Apr 3, 2013 | 10:07 AM
dsnyder586's Avatar
There is a plastic square around the throttle cable that is Zip-tied diagonally to a bracket on the throttle body. Break off the Zip-tie, lift the square/cable out of the bracket and spin it to tighten or loosen the throttle cable. Click it back in place and check the throttle % on the scanner when the pedal is down to the floor. repeat and adjust until 100% is just reached. Put a new zip tie in place and you are good to go.
MrWhite
19
Jun 14, 2022 07:49 PM
RSpi
Mar 21, 2016 12:02 PM
Dave1109971
Dec 15, 2015 06:16 PM
xjrjag
Oct 12, 2015 03:16 PM
thedugger1
Sep 26, 2015 10:27 PM
