Tilt still jams
Old Dec 2, 2012 | 10:54 PM
Bigvettefreak's Avatar
Default Tilt still jams
I pulled the tilt motor out of my 1998 XK8 and removed the spring washer as is the fix for a jamming tilt motor only to find it still jams every once in a while.
Should I have done something else? I followed the DIY pictures and procedures step by step to the letter.
Old Dec 3, 2012 | 06:22 AM
WhiteXKR's Avatar
That fix never panned out as being fully reliable unfortunely.
Old Dec 3, 2012 | 11:33 AM
scardini1's Avatar
Mine does this too - doesn't raise completely a/o drop into the memorized position. It can be "bumped" further along by repeatedly toggling the button though. Is this common to the problem as well?
I have to assume that the column's tilt action stops (jams) prematurely due to some sort of torque sensing issue. Has anyone identified a particular component, flaw or malfunction that would be responsible for this? (and be "the" guarranteed fix).
Old Dec 3, 2012 | 11:42 AM
malbec's Avatar
I notice that when the engine has been running the auto tilt works perfectly but not if the car has been standing for a while. I put in a new battery but it has made no difference. It's odd because when the engine is first started the system is still notchy. I can't figure out what's going on.
Old Dec 3, 2012 | 11:47 AM
I was afraid someone would say that. Darn!!!!!!
Old Dec 4, 2012 | 09:10 PM
Is there a fix for this problem? other than replacing the motor?
Old Dec 5, 2012 | 02:03 AM
H20boy's Avatar
I'm in the same boat. I just stopped using the 'auto' function altogether, as the reach works fine, but the tilt takes 4-5 assits to get it into position.
Old Dec 6, 2012 | 04:36 PM
Not using the auto doesn't fix the problem and I really like the auto up & down feature.
Has anyone heard of a fix for this problem?
Old Dec 6, 2012 | 04:45 PM
WhiteXKR's Avatar
Tilt motor assembly, $293.75 at Gaudin : 1998 JAGUAR XK8 Parts - Direct JPLV Porsche Parts.com
n8ertot
Oct 11, 2015 02:28 PM
WinterJag
16
Oct 9, 2015 07:49 PM
Spazzzzzzzzzy
Oct 4, 2015 05:37 PM
waynepaulj
Oct 2, 2015 04:05 PM
3jagfamily
Oct 1, 2015 01:49 AM
