Timing Chain Tensioner Replacement Question
Old Nov 25, 2010 | 11:14 PM
chrisant's Avatar
Default Also here are some pics of the cracked and broken secondary tensioners
Attached Thumbnails Timing Chain Tensioner Replacement Question-dscn0857.jpg   Timing Chain Tensioner Replacement Question-dscn0859.jpg   Timing Chain Tensioner Replacement Question-dscn0862.jpg
Old Nov 25, 2010 | 11:53 PM
garynbev's Avatar
My 99 XK8 has only 18,500 real miles. I was hoping to possibly get by with just upper tensioners, but I'm not so sure now.
Old Nov 26, 2010 | 12:59 AM
chrisant's Avatar
Default When you do the uppers just take a look at the shoes
When you do the uppers just take a look at the shoes, you will be able to tell, i don't think you will need primary s with 18,000, my XK has 130,000 miles on it, and i was just going to do uppers.. I am just very glad i took the advise of another member not to drive the car, i would have launched the engine for sure!
Old Nov 26, 2010 | 01:39 AM
Dan R's Avatar
I think that most people do the secondary tensioners only.
The primaries are more durable.
Old Nov 26, 2010 | 08:52 AM
WhiteXKR's Avatar
With such low miles, you are probably OK with just doing the secondaries.
The exception would be if the vehicle has ever had an overheating event, then I would replace it all.
Old Nov 26, 2010 | 12:25 PM
garynbev's Avatar
Default Upper Tensioners replacement diagrams
Are there any step by step diagrams or photos to cover the replacement of the upper tensioners only on the 4.0 engine?
Old Nov 26, 2010 | 12:52 PM
Dennis07's Avatar
All kinds of resources here to help you.
A good starting point might be to review the whole thread starting at ...
https://www.jaguarforums.com/forum/s...59&postcount=1
As with so many other topics, a visit to the FAQs (found within the "sticky" threads that always appear at the top of the thread list) is a good way to move quickly up the learning curve. Saved my butt more than once.
Good luck ...
Old Nov 26, 2010 | 01:00 PM
  #28
garynbev's Avatar
Default A thousand thanks
Really great not to have to invent the wheel all over again.
My hat is off to all those who care and help. Thanks a million!
Old Nov 27, 2010 | 01:09 AM
H20boy's Avatar
Good catch chrisant, glad you aren't the procrastinator type..."I'll do the tensioners in the spring, when the weather (and garage) is more comfortable". A+ for you, you're car appreciates it.
Old Nov 27, 2010 | 04:07 PM
  #30
chrisant's Avatar
Default Timing cover removed & primary & secondary tensioners
Thanks, Matt, and Yea its Cold here in my garage here as well, wait if you can..Here are some pictures of what the Primary tensioners look like after 130,000 Mi. Not good as you can see the right bank shoe got chewed up by the right primary chain, all the shoes and primary s tensioners are cracked, just like the secondary s crack just cant believe it still didn't jump time, I was very lucky, The job sucked because someone broke a bolt in the harmonic balance pulley, i had to drill and tap it blind, cant see it! can only feel it! Without that as you know there is no getting the timing cover off! Glad its done! Highly recommend getting a look at those primary shoes if you are up over 100,000 Mi. Thanks.. Chris
Attached Thumbnails Timing Chain Tensioner Replacement Question-dscn0885.jpg   Timing Chain Tensioner Replacement Question-dscn0886.jpg   Timing Chain Tensioner Replacement Question-dscn0882.jpg   Timing Chain Tensioner Replacement Question-dscn0877.jpg   Timing Chain Tensioner Replacement Question-dscn0876.jpg
Old Nov 27, 2010 | 05:42 PM
  #31
test point's Avatar
Great photo's!
Looks like you saved yourself an engine there.
xjrjag
Nov 27, 2025 09:16 AM
lobsterD90
Nov 12, 2022 09:51 PM
celticpiping
Sep 18, 2015 06:17 PM
Bcrary3
Sep 12, 2015 08:43 AM
souldoubt
Aug 25, 2015 08:15 PM
