Transgo pressure regulator upgrade
Old Sep 26, 2019 | 09:56 AM
RJ237's Avatar
No, nothing falls out, but it can be difficult to remove and require some careful prying.
Old Sep 26, 2019 | 11:06 AM
JayJagJay's Avatar
Shweeeeeet!!! Good to know.
It's info like that that makes alllllll the difference for a learner like me. THANK YOU!
Old Dec 15, 2019 | 04:02 PM
michaelh's Avatar
I did this last weekend and the how-to made it easy - thanks again BobRoy and DonB
A day in the freezer and a coating of ATF allowed the new valve to slide in without a hitch.
Two things I would add:
Vaseline is fine as a substitute for assembly gel if it's not in your inventory (confirmed by Transgo) and;
Torque figures:- TSB307-03 stresses the two different torques for the small & larger headed VB bolts.
File Type: pdf
Old Dec 15, 2019 | 05:59 PM
Jon89's Avatar
Well done....
Old Feb 15, 2020 | 09:20 AM
michaelh's Avatar
Well, I spoke a little too soon.
I finished all the other jobs on this PM schedule, so I was ready to start the car and complete the trans fluid fill.
The motor fired up on the button as always. OK, lets cycle the gears. Shift lever wouldn't come out of park, although solenoid clearly actuating.
Despite Don's clear pictures, I somehow managed to jam the shift mechanism. I was careful to ensure that the pin was in the slot when refitting the lower VB, and all seemed free and OK. Unfortunately, I didn't check again after I'd torqued up the VB bolts.
All it needed was the bolts slackening and a little gentle wiggling on the selector valve then all was well.
Seems I'm the first to get this wrong, so I'm claiming the of the week award. Upside is I've got the first flush in early
For anyone following, please check this while you're doing the final torquing on the lower VB.
Old Dec 20, 2020 | 01:53 PM
thomash85715's Avatar
Might I ask here which of the "early" transmissions are prone to this failure? Was 5hp-24 the number on all of them but early serial numbers need this upgrade while later ones do not? Or do later cars have entirely different transmissions in them? Or am I stating this wrong? Looking to buy a early 97 or 98 XK8 and must be on lookout. Thank you.
Old Dec 20, 2020 | 02:30 PM
michaelh's Avatar
They're all the 5HP24.
There's a chap in the UK who rebuilds these boxes as a hobby: he's a wealth of information. It appears that an uprated A-drum was introduced late 2000 as a running change:
https://www.jaguarforum.com/threads/...18/post-522653
although I'm not sure if the modified main pressure valve was introduced at the same time. This TSB on member Gus' site is relevant:
http://www.jagrepair.com/images/Auto...%20ZF5HP24.pdf
Sonnax also produced an oversize replacement, akthough that needs reaming capability.
To actually answer your question, the 6HP26 was not fitted until the advent of the 4.2 (2003MY) so I'd treat an early XK as a candidate for one of the above modifications.
Old Dec 20, 2020 | 02:58 PM
  #28
I guess my 04 xj8 4.2 had the 6hp26 then. It seemed balky from 1 to 2 but upwards from there it was always smooth. At risk of hi-jacking this thread, I will mention I came to this one after seeing info on X27 sub forum where I asked whether a person is smarter to buy a late XJS with 4.0L inline or early XK8. You can get them for about the same money. People on there referred me here about the trans issues in XK8. But what trans is in those last X27 six cylinder cars? And what bad behaviour do they exhibit if any? Thank you for this helpful info which I will track down on those lnks.
Old Dec 20, 2020 | 03:21 PM
michaelh's Avatar
Take a look at the XJS forum, and perhaps drop a post in there:
https://www.jaguarforums.com/forum/xjs-x27-32/
'Passionate' may be more apposite than 'smart' for those of us running older Jaguars, although end-of run cars usually have most of the issues sorted.
Old Sep 22, 2021 | 07:21 PM
  #30
wrd0225's Avatar
Default Transgo O-rings
What is the difference between scarf cut O-rings and sizing O-rings? Do the sizing O-rings go over the scarf O-rings on the Transgo Valve before you put it in the freezer? Please, someone explain.
Last edited by wrd0225; Sep 22, 2021 at 07:24 PM. Reason: and what lubricant to use for Transgo valve when inserting in valve body?
Old Sep 22, 2021 | 07:34 PM
  #31
JayJagJay's Avatar
Yes. Put the sizing rings on/over the scarf overnight before installing. The day of smear with assembly goo and quickly slide it home into the valve body. REMOVE the shrinkers first - of course.
Old Sep 22, 2021 | 07:37 PM
  #32
JayJagJay's Avatar
Oh... The sizing rings (I would guess) are of a different material and NOT to be used in the application of the valve in a hot trans thru a million hot and cold cycles and the huge pressures you will find in a valve body... The scarf (if that's the name) are suited for this purpose...
Don't worry about the difference. Just use the rings transgo says are the ones FOR the valve.
Old Sep 22, 2021 | 09:03 PM
  #33
tjankovs's Avatar
I was hopeful this procedure would cure my trans issue but it did not. I have a 1st gear slip from a stop, then bang into gear. It only happens when the trans is hot. If I lightly feather the throttle it will go into gear just fine. Any ideas on next steps?
TJ
Old Sep 24, 2021 | 05:30 AM
  #34
CA Jag's Avatar
How many miles?
Old Sep 24, 2021 | 06:09 AM
  #35
BobRoy's Avatar
TJ
It might be the early signs of a failing A drum. The Transgo is to help prevent A drum failure by reducing the spikes in pressure that are believed to cause the failure along with the origional A drum design. If it had already started to fail the Transgo wouldn't help.You will often get a check engine light with the failure. I don't recall the error code off hand. Whould need to do a search to refresh my memory but I don't have the time this morning.
Old Sep 24, 2021 | 07:29 AM
  #36
JayJagJay's Avatar
See image. My understanding is/was that either the A drum failed,,, or it has not. I'm sure there could be situations of weakening and in some cases fractures, that its just a matter of time no matter what steps are taken, but (from what I understood) if the seal is still good (a large Oring I think) and the drum is structurally sound and intact - even IF you were getting pressure spikes the transgo product should save the day - and heartaches...
It's, according to transgo and what I have read, a good preventative, intervention and solution which will completely avert failure when caught early.
Old Sep 24, 2021 | 06:27 PM
  #37
tjankovs's Avatar
Thanks for the replies. The car has 125k. No trans error codes yet. When a accelerate after a complete cool down(overnight), I hear a metallic whirring in 1st as well. It goes away after a few min of driving or if I accelerate more gently. Does this indicate A drum damage?
I appreciate the help.
TJ
Old Nov 10, 2025 | 08:57 AM
  #38
Cyrilmoto's Avatar
So I'll revive this thread...
Will it have any effect on the result of the valve replacement if I install the split rings on the valve a few days before installing the valve in the transmission? If the split rings crack when I install them on the valve, it's game over...And before I get a new valve, I don't want to have a car unnecessarily disassembled. The replacement instructions are very nicely described here on the forum, but unfortunately I couldn't find instructions on how to install the split rings on the valve so that they don't crack. I'm convinced that they are very fragile. I managed to get the valve in Poland, no one in the Czech Republic has one. I would like to replace it on the first try. Thank you very much for the valuable information.
Old Nov 10, 2025 | 01:52 PM
  #39
Y2KJag's Avatar
There were supposed to be instructions in the kit. But I'll tell you how to do those rings.
First, put them in a freezer for a couple of days to shrink them. If you do not you will never get the valve into the valve body. Once they're chilled good, take them and smear some trans assembly lube or ATF if you don't have any Tranny Goo or similar product. Than spread the ring slightly and slip it into its groove. Then lube up the entire valve and slide it into it's place in the valve body. You may have to fiddle a bit to get the ring to compress enough to slide in. DON'T FORCE IT.
Good luck!
Old Nov 10, 2025 | 02:20 PM
  #40
michaelh's Avatar
I don't recall any issues, although I fitted the scarfed and 'sizing' rings before the valve went into the freezer. Just be gentle and plenty of lube.
Once the valve is down to freezer temp, I very much doubt a few extra days chilling would make any difference. Just ensure it's in a sealed bag.
