Transmission Cooler Line O-rings
Old Sep 15, 2020 | 05:41 AM
giandanielxk8's Avatar
Default Transmission Cooler Line O-rings
Does anyone know the part number for the transmission fluid cooler line o-rings?
When I changed the radiator, I also changed the o-rings, but I used universal O-rings of the closest size I could find. The result is that its leaking a small amount of trans fluid. I have barely driven the Jag because of this.
Old Sep 16, 2020 | 10:27 AM
Update, turns out what I was seeing is not a trans fluid leak from the cooler lines. Instead I have a motor oil leak that leaks from somewhere above the front lower control arm bush.
I’m guessing it’s the valve cover even though I replaced it less than 8 months ago. Probably because for some odd reason, the Mahle cover came with insufficient stud grommets. I’m thinking of buying an entire set of grommets and replacing them. Hopefully that takes care of the leak.
Old Jun 7, 2022 | 05:11 PM
stevepaa's Avatar
Anyone know the correct part number for 2001 XK8 4.0 transmission oil cooler line o-ring? My parts list says Part number EBC4899 was superseded by part number C2C6713. But the dealers say this is incorrect?
Old Jun 9, 2022 | 11:48 AM
michaelh's Avatar
Probably a little late by now, but FWIW I called the parts guy at our dealership to order some spares today. He confirmed your C2C6713 number above.
Old Jun 10, 2022 | 09:44 AM
stevepaa's Avatar
A local dealer confirmed part number and I got them yesterday form them.
thanks
razorboy
Jun 17, 2023 08:24 PM
Catmobile
Jan 3, 2021 03:18 PM
JaguarJae
Mar 31, 2014 10:41 PM
aCapiz
Sep 13, 2013 07:04 PM
Terry
Mar 23, 2013 12:28 PM
