Trouble filling XK8 with gas
Old Jan 7, 2011 | 08:06 PM
bobk's Avatar
Default Trouble filling XK8 with gas
I've got 1/4 of a tank of gas left in my 2001 XK8 and now having trouble filling the tank. Having done some online research, I've come to the conclusion that the problem is with the CCV. Not a technical guy but want to know what I'm getting into with my auto shop. So with this in mind, can someone tell me basics of cannister close valve, where it's LOCATED. Does the repair/replacement involve removing the gas tank? What is the relation to the carbon canister assembly (if any, and what this thing does) and any relation to the EVAP valve (and what that thing does.) I know these are a lot of questions so really, I'd just be happy to get a detailed description of the location of the CCV. Thanks!
BobK
Old Jan 8, 2011 | 04:28 PM
bobk's Avatar
Hey, thanks for all your help guys & gals.
Old Jan 10, 2011 | 02:49 AM
test point's Avatar
Default Tsb 303-s841
Sorry no one has gotten back to you but I have found that there is much higher traffic on the car specific forums such as the XK8/R one.
The fuel fill problem has been around for some time and the subject of a recall on your vehicle while under warranty. The attached file contains the actual recall document. Also, there was a TSB on the specific issue you describe. Try a search on ' fuel tank filling' for several discussions.
Old Jan 10, 2011 | 03:01 AM
test point's Avatar
Default Tsb 310-10
Also, found that you cannot add another link to a file in an edit. Here is the TSB on the specific fill problem.
Old Jan 11, 2011 | 06:37 AM
bobk's Avatar
A true thank you for your help. Sorry about the whine, it must have been spoiled!
BobK
Jandreu
Jun 30, 2022 03:10 PM
Papelione
Sep 21, 2015 06:13 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
alpecsa
Sep 7, 2015 11:55 AM
