Turn signal side repeater light
Old Apr 6, 2020 | 10:48 AM
Atlastajag1's Avatar
Default Turn signal side repeater light
I have just finished repairing - replacing the plastic springy retainer with an epoxied-in SS flat spring - one of the side repeaters.
It seems that there ought to be some sort of a gasket or seal around / under the lip of this fixture, as it seems a bit crude to have the plastic housing hard up against the paint. The lack of a seal would allow water to run down the fender, up against the module, and inside the fender. I checked the other side, and there is no gasket on that one either. Then I checked the parts manual, and no (separate) gasket is shown. Can anyone comment?
Old Apr 6, 2020 | 12:24 PM
bladerunner919's Avatar
I don't recall there being a gasket. Rain water runs in all sorts of places, including inside the door skin, so I wouldn't worry about it.
Old Apr 6, 2020 | 12:37 PM
Jon89's Avatar
Yep, no rubber gasket there if I remember correctly....
Old Apr 6, 2020 | 10:24 PM
bcprice36's Avatar
Atlatajag1....
There is no gasket....Even the Leaper had no gasket.....I've not noticed any problems without a gasket.....but you could put some of that gasket stuff that's in a tube around it, if it would make you feel better!!! Only problem I've ever had with the Repeater is the Brushes in the Car Wash.....
Billy Clyde
XJ6Paul
Jun 4, 2019 01:23 PM
tedwone
29
Jan 21, 2018 09:41 AM
Flatspin
Nov 2, 2017 09:40 AM
TexMurphy
Mar 15, 2016 04:01 PM
