US import XKR 4.2 no keys
Visited the Jaguar again today, but the Immobilizer routine failed, and module scan shows a red cross through the ECM and an orange question mark for the KTM. When I select CAN Network as Selected Symptom i get over 20 100% matches, all kind of modules lost contact with CAN, ECM module as well.
I also see a question mark re the KTM on an SDD scan. Perhaps that's normal on a 'broken' car as it's apparently an optional module? Excerpt from PLATFORM_X103.exml in SDD:
<module>
<module_code_name acronym="KTM" ISOName="KTM">KTM_SYSTEM_A</module_code_name>
<address type="phys" session="diag">0x48</address>
<network>ISO</network>
<data_identifier_set type="NET">legacy</data_identifier_set>
<fitment>optional</fitment>
<tm id="@J_M_ACRO_KTM"/>
</module>
Did you see the red X for the ECM on your original scan? If not, did you manage to get a VID block read?
There is a rectification process in SDD - see attached. Programming the ECM 'as new' might be an issue if the data is incorrect in any of the other modules the process interrogates.
I'd definitely choose the Rotunda over the clone for programming.
The eeprom I pulled from the wet KTM read mostly FF other than 3 bytes. Whether that was from the water damage or someone's failed attempt to run immo setup, IDK.
Terryble
Oct 15, 2022 03:05 AM
brett1930
Apr 10, 2020 03:15 AM
