Valve Cover Bolt Replacement?
Old Mar 30, 2017 | 09:36 PM
jobagadonuts's Avatar
Default Valve Cover Bolt Replacement?
I've ditched the plastic engine covers and want to pretty-up the engine. I wanted to replace the valve cover bolts but they seem to be integrated into the covers themselves. Any ideas on how to remove and replace the bolts without losing the integrity of the valve covers?
Old Mar 31, 2017 | 03:16 AM
You've discarded the two engine covers (arrowed in red) ........
........ they are only secured on three extended bolts (circled in red) with rubber plugs:
You could simply replace the extended bolts with the same standard ones used to secure the other locations in the cam covers.
If you have oiltight cam covers now, consider yourself lucky. Disturbing any of the bolts is likely induce leaks.
Old Mar 31, 2017 | 09:01 AM
Gus's Avatar
Gus
Just know that the top rear bolt is a special bolt made not to interfere with the cam sensor and this is for both sides.
Gus
www.jagrepair.com
Old Mar 31, 2017 | 05:32 PM
Dale Dunn's Avatar
If you're wanting to get rid of covers I'm looking for a set
Old Apr 2, 2017 | 03:40 PM
Dale Dunn's Avatar
Anyone know what the special 2 bolts are made of?
Old Apr 2, 2017 | 04:49 PM
Gus's Avatar
Gus
I have no idea.
