Valve cover gasket set
Old Feb 9, 2019 | 06:04 PM
MDsjag's Avatar
Default Valve cover gasket set
Is it possible to buy a complete valve cover gasket set? I’m having trouble locating this for 97 4.0 XK8.
Old Feb 9, 2019 | 07:13 PM
RJ237's Avatar
This is the set I bought for my 97 several years ago. I think it's actually cheaper now.:
Valve Cover Gasket Kit by Motorcars Ltd part NCA2515/2516AE - MotorcarsLtd.com
Old Feb 9, 2019 | 07:16 PM
RJ237's Avatar
oops- you also need a set of isolators, that's why it's cheaper.
Valve Cover Isolator - MotorcarsLtd.com
Old Feb 9, 2019 | 08:44 PM
DavidYau's Avatar
Default 1999 XK8 4.0L Convertible in Bahrain
I presume you mean the camshaft cover gasket. Try https://www.terrysjag.com/
Great service with on line chat with someone in case you have a problem. Just be careful with your 1997 Gen1 model, as my 1999 XK8 had the AJ26 engine switched out for a AJ27 engine. The two engines have a different gasket sets. as can be seen from Terry's Jag website.
Old Feb 9, 2019 | 09:08 PM
zray's Avatar
There is also some information on the sticky list, the OEM parts interchange topic, that might be useful.
Z
Old Feb 10, 2019 | 09:24 AM
MDsjag's Avatar
Ft
Old Feb 10, 2019 | 09:25 AM
MDsjag's Avatar
Thanks for the help! Greatly appreciated!!
wrd0225
May 5, 2024 01:30 PM
David Bedoya
Jan 15, 2017 04:12 PM
Lisa Lou
General Tech Help
Jan 23, 2016 03:24 PM
Roger77
Jan 17, 2013 09:49 AM
