Electrical connector to plug in transmission
Old Feb 7, 2019 | 05:29 PM
MDsjag's Avatar
Default Electrical connector to plug in transmission
I just installed rebuilt transmission for some reason I cannot get this electrical plug to plug in to the electrical connector on the transmission. I understand you have to twist it on but doesn’t seem to want to connect. What am I doing wrong??
Old Feb 7, 2019 | 06:45 PM
Gus's Avatar
Gus
Once the plug is lined up with the pins push in on the plug and rotate the locking ring that is on the plug. If the ring does not catch and draw the plug in you will need to adjust the lock ring and try again.
Link http://jagrepair.com/images/Transmis...n5HP24%201.jpg
Old Feb 7, 2019 | 07:37 PM
motorcarman's Avatar
There are 3 different gearboxes fitted to the X100.
ZF5HP24, ZF6HP26 and the 722.6 Mercedes (W5A580)
I HATE mystery cars!!!!!!
bob
Old Feb 7, 2019 | 09:42 PM
dsnyder586's Avatar
Ditto Gus (Assuming you have an N/A engine. Slowly rotate the plug and you will feel it "seat" then rotate the ring with the tab clockwise to draw it the rest of the way in and "Lock" it. Take a look at some pics on Google and it will make more sense.
Old Feb 9, 2019 | 05:59 PM
MDsjag's Avatar
Default Thanks So Much
I finally was able to get connector plugged in. Your help was greatly appreciated. Now I had to make new post for rotary switch/ spline problem. Any help would be appreciated. What a day!!
Old Feb 10, 2019 | 09:28 AM
MDsjag's Avatar
Thanks everyone for your help! Much appreciated!!
car5car
Aug 12, 2019 06:33 PM
jnasios
Jun 15, 2018 01:47 PM
Jason Holman
Apr 14, 2017 07:12 PM
ccc
Jan 4, 2010 10:22 AM
