Valve Cover Seal
Old Apr 27, 2011 | 10:41 AM
platinummaker's Avatar
Default Valve Cover Seal
Thanks to all on this forum and the wisdom from all so generously shared, I've decided to earn my man badge and put in new secondary tensioners on my recently aquired 98 XK8 converable, 69K miles.
I will be ordering all the requisite parts and gaskets shortly, however,as I realize this is not a small block chevy, I am not clear whether any use of RTV will be needed on helping to seal the valve cover gaskets.
Any feedback greatly appreciated.
Thanks again.
98 XK8 Convert
99XJR
89 XJS w/ F1R supercharged 434 cu small block Chevy and 700R4 (just had to)
Old Apr 27, 2011 | 10:57 AM
Paul Pavlik's Avatar
I didn't use any RTV when I did the job. However, a small dab of RTV is recommended where the Engine Front Cover meets the Engine Block.
I have no leaks (without the RTV).
Old Apr 27, 2011 | 06:56 PM
mike66's Avatar
I'll second that.
Old Apr 27, 2011 | 09:13 PM
beauregard's Avatar
As they said, just the dabs at the mating surfaces, also important is sealing surfaces clean and dry, correct torque values and correct sequence- see JTIS
Old Apr 28, 2011 | 02:57 PM
Thanks guys. Appreciate the coaching
xjrjag
Oct 24, 2024 03:09 PM
bamforp
Aug 14, 2024 05:36 PM
convincor
Sep 10, 2015 06:50 AM
jaggermang
Sep 8, 2015 07:07 PM
jfitzoz
Sep 7, 2015 04:28 AM
