Vertical play in steering wheel?
Old Jan 9, 2017 | 10:17 AM
Cabel's Avatar
Default Vertical play in steering wheel?
I have about 1/4" of vertical slop in the steering wheel, figure this is most likely an issue with the tilt motor? Anyome have this issue and is there a documented fix? I didnt see it in the how-to's. Thanks!
Old Jan 9, 2017 | 10:52 AM
rothwell's Avatar
I have noticed that my wheel ends up with some vertical travel after I fiddle with the position controls. I don't remember the travel being that much though. If I fiddle with the position again it goes away. I don't use the Auto position feature so it stays put.
Have not yet bothered to determine the cause. It is curious for sure.
Old Jan 9, 2017 | 11:08 AM
hm1's Avatar
hm1
There's a nut that compresses a spring under the steering column, it needs to be tightened. Easy fix. It's been covered in the forum, do a search
Old Jan 9, 2017 | 05:11 PM
Jandreu's Avatar
Mine has about 1/4" movement if it's not full up or full down. Drives me crazy as I keep my wheel about mid travel. Took everything apart to see what's what and it looks like a worn bushing to me. When the wheel is full up or down it rests on the assembly so it doesn't move.
Any repair info and I'm in!
Old Jan 9, 2017 | 07:09 PM
Anthony8858's Avatar
Here's the thread about a loose steering column:
Read down, it'll give you a few possibilities.
https://www.jaguarforums.com/forum/x...-loose-146817/
