Very slight leak of something
Old 01-02-2010, 06:48 PM
SeismicGuy's Avatar
Default Very slight leak of something
I noticed a couple of spots in my garage that indicates a very minor leak. If I try and line up the spots with the car it looks like maybe about halfway back along the length of the engine on the passenger side. The fluid looks reddish in color and the leak is literally just a spot here and there.
I will be bringing the car in soon anyway but did anyone have any insight as to what might be leaking?
Thanks,
Doug
Old 01-02-2010, 07:16 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
I had a leak in the plastic connector between the passenger side engine and the heater hose mess behind it. Only a few drops and appeared to be red transmission fluid but was orange coolant. Took forever to decide that it was the connector. After research, that connector has a history of small leaks and, as far as I am concerned, is not repairable. You have to remove the TB to get to it and it is still a bear. Another poster cut the tubing and used a piece of heater hose and clamps to stop the leak.
Hope your leak is something else.
Old 01-02-2010, 07:37 PM
Gus's Avatar
Gus
Gus is online now
Received 2,208 Likes on 1,700 Posts
A leak does not always mean a major problem just another opportunity. Let us know what you find.
Old 01-03-2010, 07:28 PM
hlgeorge's Avatar
Had a similar leak. Turned out to be the motor mount!!
Old 01-03-2010, 07:35 PM
Gus's Avatar
Gus
Gus is online now
I have not looked at the mounts yet, I am still working on my belt problem but they will be next…
bamforp
09-26-2021 08:04 AM
Jandreu
09-20-2015 08:20 AM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
OkieTim
09-08-2015 04:48 PM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Very slight leak of something
