Voltage Reduction System - Convertible Hydraulics
Old Feb 16, 2011 | 05:58 AM
  #141
test point's Avatar
I just cut the plastic insulation off in order to use the shrink wrap.
Old Feb 16, 2011 | 10:16 AM
  #142
DougBoost's Avatar
Originally Posted by Dennis07
There is nothing new under the sun. I did not know this, but a common practice in the auto industry for some time has been to insert a resistor in series with the fuel pump to lower its voltage. This is, of course, exactly what we're doing here for the convertible top hydraulic pump.
In the fuel pump application, the resistor is automatically switched in and out as needed. When needed, it is switched in so the pump will not create too much pressure(!) and also to lessen power dissipation in the pump. It is switched out when high flow from the pump is needed. Resistor values are typically chosen so as to lower the pump voltage to 8-10 volts. In our convertible top system, the target is about 8 volts.
(This practice is now giving way to PWM (pulse width modulation) as a means of fuel pump voltage control. PWM is more energy-efficient and can provide variable pump voltage. But PWM would not be a good choice for our purposes because of cost and complexity, and because energy efficiency is unimportant with the convertible top pump running so infrequently.)
Here's a thread selected almost at random that discusses this practice ...
http://www.rx7club.com/showthread.php?t=786591
The resistors shown are heftier than the ones we use, but this is so because they have to work full-time.
So the "resistor method" is not such a peculiar idea after all. Sometimes the problem picks its own solution. It's deja vu all over again.
Brilliant! As a fellow EE and recent XK8 convertible owner I thank you for all your efforts on this Dennis.
Old Feb 16, 2011 | 10:21 AM
  #143
WhiteXKR's Avatar
My '89 Jeep Cherokee also has a resistor in series with the fuel pump.
It is supposed to reduce pump noise and extend pump life. FWIW, after 22 years and 185K miles, the fuel pump is one of the few parts (other than the engine and drivetrain) that has never failed.
Old Feb 16, 2011 | 11:58 AM
  #144
Reverend Sam's Avatar
Actually, now that I think about it, the fan speed control for the climate control system on most cars (at least on older ones) is just a resistor pack. Turning the dial just switches different resistors in and out of the circuit. Chrysler Sebrings have a notorious problem with their resistor pack because the low speed resistor burns out frequently. When that happens the fan will only blow on high speed. I've changed out several of them. So there's another example in which a resistor is used to control the power output of a motor.
Old Feb 18, 2011 | 06:49 PM
  #145
Dennis07's Avatar
Thanks, DougBoost, for the kind words. I have been helped so often, by so many people on this forum, that I could scarcely count the times. So the chance to make any contribution is welcome. Quite a place, this is.
Today, in the midst of the worst northeast winter in memory, I woke to a 60+ degree day in Annapolis, Md., confidently put my pressure-reduced convertible top down, and drove home to NJ. Nobody saw this weather coming a week ago, but we'll take it.
Old Mar 3, 2011 | 03:27 PM
  #146
xenophobe's Avatar
I just ordered this:
.22 Ohm 100w resistor. It's not as cheap as the ebay one, but it'll probably arrive a little more quickly:
http://www.newark.com/jsp/search/pro...FC-GB100000001
Old Mar 3, 2011 | 11:35 PM
  #147
Mark104's Avatar
Default My first mod
Xenophobe,
Thanks for the domestic link. I didn't want to order from Hong Kong and wait a month. I just ordered the .22 ohm 100 watt resistor frm Newark.com.
This will be my first mod to my cat!
Maybe that is why I am still a junior member!
Old Mar 8, 2011 | 06:42 PM
  #148
Boris's Avatar
Question duplicate Jag connector source?
After a series of mishaps both related and unrelated to my '99 XK8, and right after I resolve my current "cylinder wash" starting problem, I think I'm ready to install your no-cut solution to the pump's electrics. Thanks for your instructions copy-very well done!! To avoid lost time searching and fiddling with misc non-fitting connectors, has anyone found a straightforward source for a 2-line connector that duplicates the stock unit or a compatible connector that works right off the bat?
Old Mar 8, 2011 | 07:20 PM
  #149
test point's Avatar
Installing a pair of male/female connectors would, indeed, allow installing the resistor where ever you choose. But that is not necessary. The no-cut installation could be shortened into only about 3 inches between the Jaguar connectors and zip tied into an attractive installation.
No, I do not know of compatible connectors.
Old Mar 9, 2011 | 09:53 AM
  #150
Boris's Avatar
Thanks mucho for the suggestion. And, again, thanks to those who came up with this approach.
I'm thinking that this pump-pressure solution is so elegant that it demands an elegant application. Simply put, my aesthetic sense is kicking in. Having two "stock" conectors sitting side by side would be really impressive and, for the Concourse types, very appropriate.
Old Mar 9, 2011 | 12:19 PM
  #151
Mark104's Avatar
Just find a junk yard jaguar and cut the connectors off to use them for your installation.
Old Mar 9, 2011 | 12:23 PM
  #152
Mark104's Avatar
Default Got my Resistor in
I ordered the .22ohm 100w resistor from Newark.com last Saturday and got it today.
It Is Huge. I will put it in in the next few days and let you know how it goes!
Here is a pick of it on a $5 bill for size comparison.
Attached Thumbnails Voltage Reduction System - Convertible Hydraulics-img01180-20110309-1208.jpg
Old Mar 9, 2011 | 06:07 PM
  #153
hlgeorge's Avatar
Yes, has to be fairly large to handle the current draw!
Old Mar 10, 2011 | 12:56 PM
  #154
Boris's Avatar
Mark, great idea except for the little fact that the nearest Jag junkie is some 50 miles away and at $4.13 per gallon, that's a mighty expensive connector. Postage tain't much better so I think I'll settle for the Radio Shack type for the time being.
Old Mar 10, 2011 | 05:11 PM
  #155
Mark104's Avatar
My resistor from Newark.com in SC was just under $20 delivered in 2 business days.
Old Mar 11, 2011 | 11:51 AM
  #156
DougBoost's Avatar
Thanks for the picture since I got mine from there and it was less than half the size I expected after reading the doc! As hlgeorge noted, 100W is a lot of power to dissipate.
Old Mar 11, 2011 | 12:25 PM
  #157
Dennis07's Avatar
The resistor they sent to Mark104 really is a big guy compared to others I've seen. Not that there's anything wrong with that ...
Doug, where did you get yours (if the info is handy)?
Old Mar 11, 2011 | 06:15 PM
  #158
DougBoost's Avatar
I got mine from Newark also. Great service (online ordering showed they had 26 in stock, gave lots of email confirmations, tracking number, etc.). Took less than a week to get.
I was a little concerned I didn't know the trick to pull the Jag connector apart but there is no hidden tang or lock, it's just quite snug due to little "ramps" on the male side of the connector body. I installed it in same manner as Testpoint and even added some electrical tape where my leads went into the connectors just to be sure there'd be no shorts if things bounced around a little.
Works perfectly with key off, and nice to know we have pressure in reserve if need it simply by starting the car!
Old Mar 16, 2011 | 08:08 PM
  #159
lorwood's Avatar
Just finished and it works great! 16 ga heat resistant wire and 1/4" connectors from auto zone 3/16 connectors from Radio Shack directly to resistor (Newark) took about an hour. Zip ties made everything tidy. Now a trip to JAGPRO in Bellmore NY for fluid and filter changes and a once over and I hope to be good to go! Thanks Guys!
Old Mar 17, 2011 | 03:36 PM
  #160
reko19's Avatar
anybody has a link to male / female connectors and contacts? I went thru entire thread, can't seem to find it. Thanks.
