VVT and cam timing help needed
Old Mar 5, 2017 | 07:42 PM
  #61
motorcarman's Avatar
Originally Posted by michaelh
Bob,
Isn't VVT solenoids poking out of cam cover the AJ27, or have I missed something?
I know it's a different arrangement to mine, which is why I cant help with comparative tests
Thanks,
Mike
Dale Dunn does NOT have AJ27.
bob
Old Mar 5, 2017 | 08:43 PM
  #62
"In normal operation, the ECM uses the inputs from the crank sensor and the A bank cam sensor for cylinder identification
and ignition/fuel synchronization. If the A bank sensor system fails, the ECM switches to the B bank inputs
. If
the crank sensor system fails, the engine will start and run using the inputs from both cam position sensors." (my emphasis)
Mike
I did not read through the engine management guide you quoted but it must refer to AJ27 as there is NO CMPS on the right ('A'bank) bank for the ECM to reference for input.
bob
Old Mar 5, 2017 | 08:48 PM
  #63
I guess I need to re-read the posts again. I thought Dale Dunn has a 1998 XK8.
Never mind.
bob
Old Mar 9, 2017 | 10:28 AM
  #64
Dale Dunn's Avatar
Got Vvt solenoids yesterday and installed. Car is running much better and not going into restricted performance anymore. Still getting an occasional 1384 and 1396 but not nearly like it was with el cheapo eBay solenoids. Think I'm just going to run for awhile and see where it goes.
