VVT selenoid irregular tapping noise?
Old May 16, 2008 | 11:50 AM
GordoCatCar's Avatar
Default VVT selenoid irregular tapping noise?
The noise I thought was secondary chain slap, may be something else. After replacing Secondary Tensioners, the noise continues.
At startup, if the engine is given aslight bump in throttle, there is a noticible noise. It is a littlemoresolid than a click, and it seems like something is moving back and forth. Like a knock on one side, then back to the other.
Originally I thought it might bea lifter tap, but it is not dependent upon engine speed.It isnot a regular tap... tap... tap... It can repeat itself, but the phase is random. It seems to be a back and forth noise
Using my trusty engine mechanics stethescope, this click/clack seems to be part of either the VVT selenoid, or VVT unit on the camshaft ends. It isnoticible on both A Bank and B Bank VVT units.
I searched "VVT"and saw references to ECM signals, oil pressure, timing retard, etc. Is there a common diagnosis for this?
BTW my engine was Sludge City when I started my Tensioner Project. However, this knock has been going on well before any de-sludging began. Could sludge have plugged an oil galley on this device; or am I hearing the selenoid click on and off? gordo
Old May 16, 2008 | 07:30 PM
jag_genius's Avatar
Default RE: VVT selenoid irregular tapping noise?
that is a common and normal noise.. to an extent.. from reading your post .. sounds normal..
JimC64
31
May 30, 2016 03:04 PM
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
