vvt solenoid rattle
Old Oct 17, 2008 | 09:54 AM
wheeble's Avatar
Default RE: vvt solenoid rattle
Based on what you said, it sounds like lack of lubrication. if you are using 5w20 oil, try going to 10w30 and make sure you fill to the top mark on the dipstick. If the oil pump is not putting out the needed pressure at low RPM (Below 1000) thicker oil might help for a while, but you'll need a new pump eventually.
You stated it only happens when the engine is up to operating temperature. The oil has a much lighter viscosity at operating temp, that's why I suspect the oil pump.
Old Oct 17, 2008 | 10:15 AM
KAZsam's Avatar
Welcome to the forum wolfy any relations to OB1
Old Oct 17, 2008 | 01:36 PM
JagtechOhio's Avatar
The AJ27 oilpump is a higher volume than the AJ26: in fact, the later pump has superceded the earlier one.
If the engine replacement was an overhauled unit from an outside supplier,perhaps it has the early pump installed. The upgrade was necessary to maintain proper oil pressure for the later style V V T units, fitted 1999 on (AJ27).
If the engine replacement was a used unit, perhaps it is an AJ26 engine that was outfitted to fit your later car...but the oil pump wasn't updated.
I haven't come across an engine with a rattle that was caused by a V V T unit: I'm sure it's possible, but my opinion is that most times they are condemned (or replaced) without verification.
Bottom line is that if the timing cover comes off your engine, replace the oil pump before you reassemble it. The cost is less than $400, and the extra work involved is five minutes if the primary chains are alreadyremoved.
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
millertic
Sep 30, 2015 08:11 PM
jjmiah217
Sep 28, 2015 09:09 AM
