Water pump replacement procedure
Old Mar 13, 2023 | 12:27 PM
Todd Wiens's Avatar
Default Water pump replacement procedure
Hello everyone,
I have searched for the step by step water pump replacement procedure. I cannot find it. I know that some of you have replaced your water pump. I haven't searched the Toob University yet. I was hoping I could find the answer here.
Any ideas?
Old Mar 13, 2023 | 08:18 PM
RJ237's Avatar
Have you tried jagrepair.com? Just about everything you could ever need is there.
Old Mar 13, 2023 | 09:12 PM
Johnken's Avatar
Todd, this may help.
https://www.jaguarforums.com/forum/x...mp#post1329468
John
Old Mar 14, 2023 | 08:46 AM
Pistnbroke's Avatar
I have written this up on here somewhere ...release the expansion tank cap,remove the serpentine belt , unbolt the pump and let the water drop into a tray below. EPLS or KISS
Old Mar 14, 2023 | 11:44 AM
drmike's Avatar
I think I followed his instructions and it was fine if a little messy. Didn't take long to do either which was good as I needed the car.
Isn't there one bolt that is extra long or something and might shear? I gave each one a whack with a hammer before removing just in case. Steel into aluminium isn't it?
Old Mar 14, 2023 | 01:19 PM
michaelh's Avatar
Torque figure is quite low at 8 Nm + 90°.
I assumed that was for new bolts, so I just did 8Nm on the replace. Not sure if they're 'stretch' bolts & didn't want to break anything...
Michael?
Jul 23, 2021 11:07 AM
purpleqn
Jun 10, 2017 03:09 PM
mgherghina
Oct 6, 2014 01:43 PM
roger.neill
Dec 22, 2013 08:39 AM
perezrp101
Apr 15, 2009 09:02 PM
