What is it?
Old Dec 5, 2012 | 10:41 PM
deelli's Avatar
Default What is it?
I need help identifying the part that is right next to (sort of forwand and a bit lower), the radiator expansion tank on a 1997 XK8, looks to have a vacuum connection and a electrical connector...want to know what this does. Thanks for any help
Old Dec 6, 2012 | 04:24 AM
dennisw's Avatar
a picture would help.can you post?
Old Dec 6, 2012 | 08:02 AM
The Coupe's Avatar
Sounds to me like you're describing the Evaporative Emissions Canister Purge Valve. I've attached a PDF below, which contains the description and function of this part as outlined in JTIS.
Old Dec 7, 2012 | 10:02 AM
deelli's Avatar
This is it and the information helped a lot...thank you so much for sharing.
Old Dec 7, 2012 | 11:00 PM
deelli's Avatar
[QUOTE=The Coupe;634541]Sounds to me like you're describing the Evaporative Emissions Canister Purge Valve. I've attached a PDF below, which contains the description and function of this part as outlined in JTIS.
.[/QUOTE
Now right below the EECPV, there is a smaller vacuum line (near the two fuel pipes), was does it go to?
Thanks again
