What does this service tag mean?
As always bang on the money. Re programmed to increase the fuel when cranking to aid cold starting . Engine temp measured at the water sender unit . If you have poor cold starting you can fool the computer with a 1000 ohm resistor in series with the sensor and a switch or relay to take it out . This makes computer think the engine is colder than it is. Available as a kit for other JLR vehicles.
Z
The kits on ebay were for LR P38 diesels which had a cold start problem when the pump was worn. When the ignition was turned on a relay with a 20 sec timer was activated and at the end of the timer period the resistor was bypassed . Lots of timers on ebay for about $5 I have one to turn my SRS light off !!!!
hilary
16
Dec 14, 2016 12:20 AM
H20boy
Jan 17, 2013 01:40 PM
