Where can I buy a Code P1646 chip
Old Oct 31, 2017 | 01:45 PM
Jubilee's Avatar
Default Where can I buy a Code P1646 chip
Linear 02 Sensor control chip (Bank1)
Old Oct 31, 2017 | 02:06 PM
avern1's Avatar
You make it very difficult to provide help. What Model/Year Jaguar do you have? Is your Jaguar an X100? Is it supercharged XKR. It would be very helpful if you put your Jaguar information in your signature.
You should drop by the New Member area and introduce yourself and you can get hints on how to add info to your signature and posing questions.
Now with all of that out of the way P1646 has nothing to do with oxygen sensors. The code is for the secondary fuel pump relay having a problem. Keep in mind that code only applies to supercharged engines.
Old Oct 31, 2017 | 04:12 PM
phanc60844's Avatar
Actually, P1646 can be either depending on the year:
VIN 001036-018108 no such code
VIN 018109-031303 Fuel pump 2
VIN 031304-A00083 Heated O2 sensor
VIN A00084-A11140 Heated O2 sensor
VIN A11141-A30645 Fuel pump 2
VIN A30646- and on Heated O2 sensor
If its an XK8 it can only be the O2 sensor anyway as there is no fuel pump 2
JessN16
Jul 22, 2018 12:07 AM
Rodders
Oct 31, 2017 03:01 AM
bommerts
Oct 26, 2017 07:05 AM
sjagerson
Oct 21, 2017 01:35 PM
Stefi88
XJ40 ( XJ81 )
Oct 12, 2017 04:51 AM
