Where is the oil?
Old Aug 5, 2017 | 07:11 PM
IXLLER8's Avatar
Default Where is the oil?
Hi...just sucked and drained my xk8 from 98 for oil...dipstick showed up to max before emptying, but I only got app 5 liters of used oil out! I refilled up to max...up to second small hole on dipstick, but only 5 liters went in...I didn't change oilfilter this time. That maybe accounts for 0,5 liters...Manual says car holds 6,5 liters, so where is the rest...or is dipstick not showing the right/correct level?
Frank
Old Aug 6, 2017 | 03:04 AM
DevonDavid's Avatar
How did you get the old oil out - did you drain the sump with the oil warm through the drain plug in the sump, or did you "suck" the oil out with one of those pump-type devices ?
If you have an oil cooler, the total capacity is, I believe, 7.3 litres but you would never be able to get all of that out unless you disconnected the cooler pipes and drained that separately.
Old Aug 6, 2017 | 09:14 AM
IXLLER8's Avatar
Hi
I did both - I sucked and drained until there was nothing left:-)
Best
Frank
Old Aug 6, 2017 | 09:57 AM
Isn't it 6L 6.4Qts?
Did you lift the car at the rear to help draining? Some do I don't.
If you are good on the dipstick you will be fine.
Old Aug 6, 2017 | 11:47 AM
DevonDavid's Avatar
Norri - that's interesting.
My "Vehicle Care" booklet (JJM 10 16 14/72) for my 1997 4.0 car says :
Engine oil capacity - with oil cooler = 7.3l and without oil cooler 6.5l
I assume the booklet gives total capacity, rather than the amount that is likely to drain out when doing an oil-change.
Old Aug 6, 2017 | 12:01 PM
I'll confess I've never measured the amount of oil I've taken out or put into an engine in my life.
I drain until it stops and fill until it hits the mark on the dipstick and sleep without worrying about it.
Old Aug 6, 2017 | 12:07 PM
joesoap's Avatar
Did mine yesterday and it took just under 7L with fresh filter.
Like Norri I just empty and fill till it hits the top mark before starting and it drops a little once filter is filled.
Sometimes with suction method the hose doesn't reach the bottom of sump and doesn't get it all out, so takes less to fill.
