Whirring noise
Old Oct 4, 2018 | 04:57 PM
samboni's Avatar
Default Whirring noise
Hi all!
My car is making an odd sound. I thought it was the top pump, but the top is fine! No messages on the dash, and an OBD reader says all clear.
It sounds like the top pump motor was running, and running, and running. But it doesn't stop or change when I operate the top in either direction, which takes about 13 seconds with the engine running. The sound seems to be coming from behind me while in either the driver or passenger seat, and only when the engine is running.
Anyone have a clue what it might be, or advice on how I might track it down? I have no idea what it is, and the not knowing is driving me nuts, thinking I might be burning something out just by driving around having it running all the time.
Thanks!
Old Oct 4, 2018 | 04:59 PM
samboni's Avatar
I know it's bad form to reply to myself, but thought I'd add some notes:
It's only when the engine is running
the sound doesn't change with engine speed or movement
it stops sometimes, but not predictably
Thanks again!
Old Oct 4, 2018 | 05:13 PM
samboni's Avatar
Inside the trunk...
https://www.dropbox.com/s/hfbrmjnf21..._2335.MOV?dl=0
Old Oct 4, 2018 | 05:34 PM
samboni's Avatar
Related? The windows don't drop when I put the top up.
Old Oct 4, 2018 | 07:34 PM
michaelh's Avatar
Noisy fuel pump?
Get a helper to turn the ignition on (position ii - on) while you have your head in the trunk. Pump should run for about 2 seconds then stop.
Only other motor I can think of other than the antenna is the fan in the audio amp - if you have premium sound - but that's ignition-on dependent rather than only when the engine is running.
Old Oct 5, 2018 | 05:26 AM
samboni's Avatar
Thanks, fuel pump is sort of mostly obvious now that you mention it and I did a little reading. The car's approaching 90k, so I guess it's time?
Old Oct 5, 2018 | 03:23 PM
michaelh's Avatar
I'd be tempted to replace the fuel filter if you don't know when/if it was last changed. It's an easy job compared to the fuel pump, which may be noisy because it's trying to push fuel through a partly-blocked filter?
Just random thoughts, but thinking of the simple things first. The pump may well be OK otherwise you might have encountered performance issues, but it's cheap PM anyway.
HTH
eastwoodsid
Sep 23, 2021 04:20 PM
trosty
Aug 4, 2014 02:17 PM
drcase
19
Oct 14, 2012 12:05 AM
Mayor111
Dec 20, 2010 02:33 PM
