Cigar lighter weirdness
Old Oct 5, 2018 | 08:13 AM
giandanielxk8's Avatar
Default Cigar lighter weirdness
The cigar lighter on my XKR works partially. It can charge my iPhone well enough, but if I plug in my portable tire inflator kit, that works fine on my Jeep, it does not power it at all. Similarly, I also can't get the heating element to actually heat up, not that I would ever use that.
I suspect it is getting insufficient voltage. I assume the problem can't be a fuse because power is getting to it. Any ideas?
Old Oct 5, 2018 | 08:32 AM
Johnken's Avatar
Seen this once it twice before due to corrosion on the connection. The gentleman who owns BAT , a company that makes very high end vacuum tube amplifiers, once told me that the best way to clean a tubes pins is to repeatedly insert and remove. The friction does the job for you.
try inserting the connector and twist around, well you get the idea.
I suppose one could find a funny shaped male connector that will have difficulty no matter what you do. I've seen that too.
Hope it helps.
John
Old Oct 5, 2018 | 08:42 AM
Hope it helps.
John
The connector as in the power source to the cigar lighter or the 12V plug of the tire inflator kit?
Old Oct 5, 2018 | 09:05 AM
fmertz's Avatar
You need to look this up, but I am not sure there is an established standard for these adapters. Some seem smaller in diameter. Some are deeper then others. Bet these devices you are talking about don't reach the bottom of the plug and therefore have no power. Don't dismiss the possibility that your cigar lighter is not original, or that the socket was somehow replaced at some point because some accessory did not fit. Last resort is to find some adapter/divider/splitter that somehow makes this all work.
Old Oct 5, 2018 | 10:01 AM
Johnken's Avatar
Guess I typed 2 fast sorry. I meant the receptacle itself, it the inside of the cylinder that holds the lighter element.
John
Old Oct 5, 2018 | 01:03 PM
Johnken's Avatar
Glandaniel, here's one of the posts I referenced. I described it better in there.https://www.jaguarforums.com/forum/x...hlight=Lighter
John
Old Oct 6, 2018 | 12:26 PM
bcprice36's Avatar
Smile
Glandaniel, You have to have the Key ON! before the Lighter will work...……..well it could be that simple!
Billy Clyde in Houston
Old Oct 6, 2018 | 02:43 PM
Unfortunately, this issue persists even with the engine on. I haven't yet had the opportunity to try the recommendations given in this thread.
bonanza
Sep 4, 2017 12:20 PM
J3Langford
Mar 25, 2013 04:31 PM
Jaguareh
Mar 1, 2008 05:25 PM
chris01xj
Feb 19, 2008 08:04 PM
Nov 19, 2007 05:10 PM
